second de personne Posted October 10, 2009 Share Posted October 10, 2009 Good evening, I write to you France and thanks to a translator. I' will like that one a explain how functions the famous grille ain intake which equip Wolf with the English army. Thank you Quote Link to comment Share on other sites More sharing options...
PaulMc Posted October 11, 2009 Share Posted October 11, 2009 Have a look at this - http://www.rapitypes.com/case_study_lrw.html The vehicle has an intake hole on each wing, same as 2.5TD/200Tdi (LH side) and 300Tdi/TD5 (RH side), the inside of the 'Wolf' intake shields these holes and forces the air drawn-in through it's grille to pass up and over an internal baffle, before entering the intake holes. The two intakes are joined together by pipework under the bonnet, before the air filter, see below - (click on thumbnail for full size image in new window) . Quote Link to comment Share on other sites More sharing options...
second de personne Posted October 11, 2009 Author Share Posted October 11, 2009 Thank you, for this answer, on the other hand on the grids that I' for my Defender, I have to buy do not have the translucent plate, is this normal???? where can I find this plate. Regards Quote Link to comment Share on other sites More sharing options...
PaulMc Posted October 11, 2009 Share Posted October 11, 2009 Thank you, for this answer, on the other hand on the grids that I' for my Defender, I have to buy do not have the translucent plate, is this normal???? where can I find this plate. Regards The exploded diagram shows all of the component parts used to make a complete intake grille. The 'translucent plate' shown is actually a piece of foam rubber, bonded to the inside back panel of the grille and designed to stop water splashes through the grille - excess water then runs off the foam rubber and exits through the drain hole (bottom right of the grille in the picture). . Quote Link to comment Share on other sites More sharing options...
second de personne Posted October 13, 2009 Author Share Posted October 13, 2009 Ok thank you very much for these explanations, therefore my grids are good, therefore I will be able the rises on my vehicle. Thank you still Quote Link to comment Share on other sites More sharing options...
