jwc Posted October 19, 2009 Share Posted October 19, 2009 (edited) Td5 2002 Defender 90, air getting into the fuel system, loosing presure & hard to start, fuel pump renewed & still noisy, any ideas ? Edited October 19, 2009 by western Please DO NOT use capitals, it's considered to be shoutting, normal lowercase text is more than adequete. Quote Link to comment Share on other sites More sharing options...
Orange Posted October 19, 2009 Share Posted October 19, 2009 Coroded or punctured fuel line? Have seen it before along the chassis rail of a Discovery and could be as small as a pin prick, but under load it causes problems... Quote Link to comment Share on other sites More sharing options...
Dave.Pretorius Posted October 27, 2009 Share Posted October 27, 2009 Td5 2002 Defender 90, air getting into the fuel system, loosing presure & hard to start, fuel pump renewed & still noisy, any ideas ? Possibly copper seals/washers on the injectors. If these are leaking the return fuel flow will carry gas bubbles from exhaust gases. A leak in fuel lines / filters will not induce gases - these lines are under pressure - they blow not suck ! It could of course simply be a case that your pump is on its way out Dave Quote Link to comment Share on other sites More sharing options...
