Stuck in high - Update
Micky-Disco
I just wanted to thank everyone who helped my in my previous post HERE
Started this morning, stripped out the console and removed the stuck bits of the transfer box so I could service them (easier out of the car)
Freed everything up, removed the rusty carp from the shaft, greased everything back up and refitted. Replaced the console and its all working and back together.
So Thank you all those that helped ;)
Well done... I guess you didn't make the mistake that I did?! Since it was quite late, and I was in a rush to get going, I threw the centre console back in quite quickly. All seemed good, elec windows worked etc. Only when I decided to drive off did I notice the driver's seat belt socket was gone! Tucked up inside the console plastic. :huh:
Now all you need is some ice and snow to make good use of the locked diff, and some mud for low range too.
