Simon119 Posted November 18, 2009 Share Posted November 18, 2009 Afternoon all I'm about to convert my truck cab TD5 90 to a van. I'm after the part numbers for the seals etc i'm going to need and if possible an exploded parts diagram of all the seals and fixings so i can check i have everything before taking my truck cab off. The base vehicle is an x reg TD5 90 and the doner roof is smooth with the interior light behind the front seats. The rear door is one with the screw in strips for retaining the glass if that makes any difference. Hope someone can help Regards Simon Quote Link to comment Share on other sites More sharing options...
western Posted November 18, 2009 Share Posted November 18, 2009 I don't have a 90 parts bok to check, but if you download Microcat from Here scroll down till you see Microcat & RAVE CD Disk Images click the first link microcat, This file is an image of the Land Rover Microcat CD in .nrg format. You will need to either burn this to a CD using an application such as Nero or create a virtual drive with Power ISO & then browse at your leisure Quote Link to comment Share on other sites More sharing options...
