mobyone Posted November 22, 2009 Share Posted November 22, 2009 can anyone tell me how to set the rod length to the correct length for the wastegate actuator. and also, does the actuator push the rod away from the bulkhead towards the front, or does it pull the rod from the front towards the bulkhead. i was checking to see if the wastegate moved freely, and like a tool i never checked first. thanks all who reply richard Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted November 23, 2009 Share Posted November 23, 2009 I not so sure the length is fixed as other variables come into play…….. 200 or 300 tdi ? ........ although they will be very, very similar. The correct way is to measure the boost pressure by fitting a T piece into the actuator hose and a pressure gauge onto the T section……..IIRC for the 300tdi the correct pressure is 13.5 to 15.5 psi at 2500 – 3000rpm. Quote Link to comment Share on other sites More sharing options...
