ally Posted December 1, 2009 Share Posted December 1, 2009 hi guys apart from the clutch slipping and rear hub seal leaking everything was not too bad.now i have the ENGINE CHECK LIGHT,coming on intermitantly it only comes on when i start the engine, if i stop and take key out and restart it normally goes away.2000 td5 any ideas? do i need to get a fault code. thanks in advance Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted December 1, 2009 Share Posted December 1, 2009 In short........YES.........it will need to be put on a diagnostic's machine sooner rather than later. Post your location and someone might be close enough to help out. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 1, 2009 Share Posted December 1, 2009 yes you need to plug it into a diagnostic computer - anything else is just guessing Quote Link to comment Share on other sites More sharing options...
