gaz0203 Posted December 3, 2009 Share Posted December 3, 2009 got a td5 90 in tomorow with a rough idle, in the last 6 months its had new injector harness and wiring loom after it started running on 3 cylinders, it then died completely so had a new fuel pump and filter fitted, it sems to go well but as i say just runs rough at idle. ive just been reading posts on here an see mentioned checking injectors are adjusted correctly, ive never heard of this so just wandered whether this could be causing me problems, if so how do i go about making adjustments?? Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted December 3, 2009 Share Posted December 3, 2009 What is the cylinder balancing reading on live data ? Quote Link to comment Share on other sites More sharing options...
Orange90-J- Posted December 3, 2009 Share Posted December 3, 2009 My friend has a 90 td5 and whan he gives it a good hammering off-road mainly through fairly deep water/bogs it has a very ruff idle but this isnt all the time just for a while. never does it daily think its mainly the water/mud floating around the ecu... cheers -J- Quote Link to comment Share on other sites More sharing options...
gaz0203 Posted December 3, 2009 Author Share Posted December 3, 2009 unsure as yet, will hav a nose tomorow wen it comes in, what should they read? Quote Link to comment Share on other sites More sharing options...
Orange90-J- Posted December 3, 2009 Share Posted December 3, 2009 Should be all around the same (not sure on the exact readings) if ther is a big difference between them it would cause ruff tickover like it had a miss-fire. Quote Link to comment Share on other sites More sharing options...
gaz0203 Posted December 4, 2009 Author Share Posted December 4, 2009 had a look today and our scanner wont read injector data for some reason, i rang our local landrover specialist to ask there opinion which was injectors, i asked whetehr there was any adjustment and was told no, i removed the rocker box just to get myself aquainted with the setup and see that there is adjustment at the top of the injectors, how do you measure these and what shouldbthey be set to? Quote Link to comment Share on other sites More sharing options...
