w_heily Posted January 3, 2010 Share Posted January 3, 2010 i was thinking of putting a shortend 110 chassis under my range rover the rails are stronger and would give body lift as a bonus the tail behind the wheels is shorter though Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 4, 2010 Share Posted January 4, 2010 A lot of work and you would need an IVA if you intend to put it on the road. The RR chassis is that long as it supports the body - which is that long! Using a shorter chassis wont work IMHO. (Unless you bobtail it....) As for stronger rails, that is true, but I have never heard of anyone having a problem with the RR rails unless they were rotten. The 110 rails would not lift the body up as the spring mounts are at the top of the rail on both models so in fact you would be pushing the bottom of the rails down. Quote Link to comment Share on other sites More sharing options...
