Bobtail Posted January 4, 2010 Share Posted January 4, 2010 i've got a 97 300tdi i have changed the glow plugs and fitted new battery after starting problems just before christmas well been on nights and came out this morning and it would not start again even tried towing it and nothing any ideas please cheers jim Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 4, 2010 Share Posted January 4, 2010 Have you checked the glow plugs are getting power (i.e. that the timer unit is working properly) - should have 12V at the plugs when you switch the ignition on, then the glowplug light on the dash will go out, a few seconds later will be an audible click and power to the plugs should shut off. Check the Alarm Spider Post in the tech archive, and follow the diagnostics on that - if it will crank but not fire, do you have power to the cutoff solenoid on the injector pump? Quote Link to comment Share on other sites More sharing options...
