broon Posted January 10, 2010 Share Posted January 10, 2010 hi having problem after motor would not start found out that the battery in the key fob was flat and the immobilser was still on with the alarm off. put new battery in key fob motor started a ok but the abs,tc,and the hd dash board lights have stayed on i have a 2lt turbo diesel 1999 freelander can anyone help thanks broon Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted January 10, 2010 Share Posted January 10, 2010 It will need diagnostics mate Quote Link to comment Share on other sites More sharing options...
errol209 Posted January 10, 2010 Share Posted January 10, 2010 It will need diagnostics mate Google for "three amigos site:lr4x4.com" Quote Link to comment Share on other sites More sharing options...
rustymark Posted January 10, 2010 Share Posted January 10, 2010 These 3 lights are common - the 3 Amigoes They indicate a fault somewhere in the ABS system normally. Anything from the wire on the HDC switch disconnecting to wheel sensors. Did you have the lights before the keyfob battery problem? Have you driven the car? The ABS will self check the wheel sensors as you drive and switch off the lights if the fault clears. As the other man said - search for the 3 amigoes on here loads of info. Quote Link to comment Share on other sites More sharing options...
broon Posted January 10, 2010 Author Share Posted January 10, 2010 These 3 lights are common - the 3 Amigoes They indicate a fault somewhere in the ABS system normally. Anything from the wire on the HDC switch disconnecting to wheel sensors. Did you have the lights before the keyfob battery problem? Have you driven the car? The ABS will self check the wheel sensors as you drive and switch off the lights if the fault clears. As the other man said - search for the 3 amigoes on here loads of info. drives fine everything normal before key fob battray went dead thanks broon Quote Link to comment Share on other sites More sharing options...
