LandyLee Posted January 17, 2010 Share Posted January 17, 2010 Before I go and buy some , do I need these with a 2" lift ? I have none fitted as of yet and I need to know whether to buy standard or extended ones ? Currently I am running +2" shocks and springs and that`s all, no -2" turrets or different shock mounts Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 17, 2010 Share Posted January 17, 2010 It is the size of the tyres that determine if you need bump stops. It has nothing to do with a lift. Somewhere a little above 33" the rear tyres will hit under full compression at the top and longer bump stops should be fitted. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 17, 2010 Share Posted January 17, 2010 Bump stops also need to be extended to stop springs bottoming out on themselves. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 17, 2010 Share Posted January 17, 2010 Bump stops also need to be extended to stop springs bottoming out on themselves. With poorly designed spring lifts..... Quote Link to comment Share on other sites More sharing options...
LandyLee Posted January 17, 2010 Author Share Posted January 17, 2010 I`m running 265/75/16 - general grabber at2s on it right now so no problems then just buy the ordinary ones ? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 17, 2010 Share Posted January 17, 2010 Yep, no need to longer stops. Quote Link to comment Share on other sites More sharing options...
