adambowling Posted January 25, 2010 Share Posted January 25, 2010 hi just bought a discovery 1995 300tdi the heater does not work, is this a common fault and would it be easy to fix? i think it might be the fans. no air is coming through at all. also it has electric windows all round, but the two on the drivers side don't work? what could be wrong with this? would this also be an easy fix? thanks adam Quote Link to comment Share on other sites More sharing options...
MrKev Posted January 25, 2010 Share Posted January 25, 2010 Hi Adam. See the 'tech archive' section of the forum, and have a browse round. the top post in there there is an index, listing all the posts worth reading. There's one on repairing the electric window ECU, which is known to be a common problem on Discoverys. On mine, it was the two rear windows that had failed, but it's worth a look, and will probably only take you about half an hour if you are moderately competent with a few tools and a soldering iron. I don't know what the likely problem is with your fans, but someone else might. I presume you've checked all the fuses? Do you have A/C - does the light on the A/C switch come on when the fan speed is set to anything other that off? Kev Quote Link to comment Share on other sites More sharing options...
ches Posted January 25, 2010 Share Posted January 25, 2010 have a read thru' this post for possible heater repair. http://forums.lr4x4.com/index.php?showtopic=51884 Quote Link to comment Share on other sites More sharing options...
Pinn76 Posted January 26, 2010 Share Posted January 26, 2010 When I bought my '94 300tdi the fan would only work on the slowest speed, bit annoying when trying to clear the screen or drive in the wet. Stripped the center of the dash out to access the control switch intending to replace but noticed it was easy to dismantle. Me being me I opened the switch and cleaned the inside terminals rebuilt and now works on all speeds. Result!!!! Quote Link to comment Share on other sites More sharing options...
pw8757 Posted January 26, 2010 Share Posted January 26, 2010 Adam, You can try a quick search of this forum by using Google as a search engine. Use "forums.lr4x4.com/what you want to find" as a UK search. In the present case, "forums.lr4x4.com/discovery electric windows" gave me on the bottom of the second page this (ironically on another forum!! ) Welcome to what must be the best forum going - and to fixing your own Disco!! Quote Link to comment Share on other sites More sharing options...
adambowling Posted February 4, 2010 Author Share Posted February 4, 2010 thanks for all the advice i have checked all the fuses and they seem to be ok. couldn't see any obvious problems so its going into a local garage tomorrow unfortunately :/ and as for the windows i'll look at the tech archives thanks for the help adam Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted February 4, 2010 Share Posted February 4, 2010 When he said "i have checked all the fuses" what he actually ment to say was "I made i my mate do it whilst i had a cigarette in his workshop" Quote Link to comment Share on other sites More sharing options...
adambowling Posted February 8, 2010 Author Share Posted February 8, 2010 too true haha Quote Link to comment Share on other sites More sharing options...
