Adam001 Posted February 3, 2010 Share Posted February 3, 2010 Hi, I need to change the rear bearing on my LT230 rear output. I know I need to remove the handbrake backplate to access the dust cover/retainer. But do I need to remove the entire bearing housing from the transfer case? Or can I remove the seal and the circlip then put the flange back on with the nut and use that to tap the whole shaft out? I know it can be done with the front bearing, but it can it be done with the rear? Cheers, Adam Quote Link to comment Share on other sites More sharing options...
reb78 Posted February 4, 2010 Share Posted February 4, 2010 Theres a good guide in the tech archive - have a glance at what else is in there using the index link at the top of the page. Lots of good stuff for future questions. Here is the one you need: http://forums.lr4x4.com/index.php?showtopic=6917 Quote Link to comment Share on other sites More sharing options...
Adam001 Posted February 4, 2010 Author Share Posted February 4, 2010 That is the guide saying to remove the whole section from the transfer box, which I wanted to avoid if I could Quote Link to comment Share on other sites More sharing options...
