hoss1720 Posted February 4, 2010 Share Posted February 4, 2010 Ive just changed the engine in my defender from a 19j to a 200 tdi. Got everything in and got it running,but I dont appear to have any igniton lights on the dash. The fuel warning light is on but nothing else. When I initially tried to start it the only light that was on was the diff lock light,but after a bit of fiddling that went off and the engine started. The main earth cable from the engine to the chassis is missing.Could this be the problem or is it something else ive damaged or missed out during the conversion? Quote Link to comment Share on other sites More sharing options...
western Posted February 4, 2010 Share Posted February 4, 2010 The main earth cable from the engine to the chassis is missing get one & fit it, your handbrake cable is probably acting as a poor subsitute, not doing the engine any favours either if you've got the original engine earth lead use that. Quote Link to comment Share on other sites More sharing options...
hoss1720 Posted February 5, 2010 Author Share Posted February 5, 2010 earth lead replaced with a new one. still no battery light. the engine strarts and runs fine. could it be the alternator? whats the best way of checking? Quote Link to comment Share on other sites More sharing options...
western Posted February 5, 2010 Share Posted February 5, 2010 check the charge light bulb is working, if it's not the alternator will not self excite/charge. Quote Link to comment Share on other sites More sharing options...
hoss1720 Posted February 6, 2010 Author Share Posted February 6, 2010 bulb checked(working)and all wiring appears to be intact so I will take the alternator and get it overhauled. cheers. Quote Link to comment Share on other sites More sharing options...
