Sputnik 1 Posted February 8, 2010 Share Posted February 8, 2010 Getting a bit peeeed off now lads - pls any advice most gratefully received. one by one my door locks are starting to either jam, stick, struggle / not respond and now struggling to be opened from either side manually. Have tried stripping cleaning and re-greasing ( although not quite sure how to get access to the guts.... ) in the process have managed to loose both rear ' pop ups ' but not worrying about them..... are my lock solenoids going soft ????? are my greased parts seizing due water ingress ???? is there a single earth or 12 v feed for all locks going high resistance ???? any ideas Quote Link to comment Share on other sites More sharing options...
cookie64 Posted March 15, 2010 Share Posted March 15, 2010 Getting a bit peeeed off now lads - pls any advice most gratefully received. one by one my door locks are starting to either jam, stick, struggle / not respond and now struggling to be opened from either side manually. Have tried stripping cleaning and re-greasing ( although not quite sure how to get access to the guts.... ) in the process have managed to loose both rear ' pop ups ' but not worrying about them..... are my lock solenoids going soft ????? are my greased parts seizing due water ingress ???? is there a single earth or 12 v feed for all locks going high resistance ???? any ideas IVE GOT THIS PROBLEM TOOO one of my rear doors wont unlock unless manually done from the inside, please is there a lil trick which will get it to work properly again??? tom Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 16, 2010 Share Posted March 16, 2010 Me too, although I'm also too lazy to take it apart and investigate Quote Link to comment Share on other sites More sharing options...
