siearl Posted February 19, 2010 Share Posted February 19, 2010 Hi all, I have a 3 door 98 s plate freelander. I have noticed with all the wet weather that where the removable roof connects with the body i am getting white streaking from water ingress. I know i need to replace the rear door seal and thought that at the same time i will do this one. Can anyone tell me what sealant to use between the body work and the actual seal and also does anyone happen to have the codes for the purchase of the seals. Thanks Si Quote Link to comment Share on other sites More sharing options...
schuee Posted February 20, 2010 Share Posted February 20, 2010 Hello Si, I had a small amount of water ingress, in my 05 plate hardback, took the hardback off and sprayed silcone spray on the seal and left it for a while and then put it back on, then cleaned any excess off. Seems to have been ok ever since. Cheers Keith Quote Link to comment Share on other sites More sharing options...
