Dave3d Posted February 21, 2010 Share Posted February 21, 2010 I have A 1997 Defender V8 and suffer from heat problems at the drivers and passengers feet. It gets very hot at our feet as well as the gearbox cover. Is this a Defender problem as I have heard of more than one person complaining or can I fix it, or at least make it a bit better. The engine does not overheat nor the gearbox-xferbox. Can be very uncomfortable at times. Is it engine or gearbox heat.? Quote Link to comment Share on other sites More sharing options...
Litch Posted February 21, 2010 Share Posted February 21, 2010 I suffered a bit with this in my old S111 V8 SWB. The problem is that the exhaust manifold is very close to the footwell and of course it gets very hot, is there (or should there be) a shield of some kind around the manifloid? The best solution is to fit a reflective heat insulator to the engine-bay side of the footwell. This stuff is available from suppliers of noise inslation material. Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted February 21, 2010 Share Posted February 21, 2010 i was thinking some exhaust wrap may help this is the first one i cam across may be cheaper out there http://cgi.ebay.co.uk/Exhaust-Wrap-10M-Roll-52mm-Wide-10-Stainless-Ties_W0QQitemZ110493706803QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item19b9f02a33 Quote Link to comment Share on other sites More sharing options...
