stevegibbs Posted March 4, 2010 Share Posted March 4, 2010 I have been asked to look at a friends Disco it is a 1996 300 tdi the abs is playing up. Start the ignition abs light on, start the engine abs light on, drive off abs light on. Now start the engine go backwards a few feet then drive forward abs light goes off but may come on again or may not. Done all the wiggle test checked fuse. Any help please. Steve Quote Link to comment Share on other sites More sharing options...
big tim Posted March 4, 2010 Share Posted March 4, 2010 Check for play in the swivals and wheel bearings as these can affect the abs system Quote Link to comment Share on other sites More sharing options...
stevegibbs Posted March 5, 2010 Author Share Posted March 5, 2010 Check for play in the swivals and wheel bearings as these can affect the abs system I have adjusted both wheel bearings that seemed to have done the trick. Then the light came back on so back to the drawing board. Any more ideas please. Steve Quote Link to comment Share on other sites More sharing options...
andy2986 Posted March 5, 2010 Share Posted March 5, 2010 Have you made sure the ABS sensors are seated properly? give them a little tap (really just a little tap!) and make sure other than that do a blink test and see what it says the fault is Andy Quote Link to comment Share on other sites More sharing options...
stevegibbs Posted March 6, 2010 Author Share Posted March 6, 2010 Have you made sure the ABS sensors are seated properly? give them a little tap (really just a little tap!) and make sure other than that do a blink test and see what it says the fault is Andy Thanks for that Andy, tell me more about the blink test Steve Quote Link to comment Share on other sites More sharing options...
andy2986 Posted March 6, 2010 Share Posted March 6, 2010 Here you go from the tech archive. you have to find the OB2 (?) connector On mine it looks like a tv scart plug near your feet, under the steering wheel. pull the abs relay, then with a paper clip or piece of wire short out two of the pins on the connector of the scart type plug, then with the ignition on the ABS light will flash a code at you in two sets, note the code and look up on the list and it should point you as to where your fault is. (its been a while since ive done it !) I first did this some time ago and got my info from the discovery owners club tech section, Ive had a quick glance through this one and seems to be similar.. Hope that helps Andy p.s. ive just re read it its simpler to do than ive tried to explain, its not a tough one honest !! Quote Link to comment Share on other sites More sharing options...
andy2986 Posted March 6, 2010 Share Posted March 6, 2010 This is the one I used (copied from the DOC forum) The ABS ECU itself is a standard Bosch/Wabco part. If you do some googling, you'll find that the same techniques and codes apply to many other vehicles that use this unit. First of all, we need to find the ABS warning light relay. On mine, it's in the passenger footwell, under the glove compartment. Lever out the 3 press-in studs, and the trim panel can drop. There are half a dozen relays in there. The one we're looking for is (on mine!) nearest to you, but in the second row, "behind" some others. Difficult to explain, but obvious when you get in there. The relay bases slide onto brackets, push them about an inch "away from the wires" and they'll come free. The one we're looking for has a green base, and has 2 black wires, 1 black/green wire and 1 brown/red wire. Disconnect this relay - pull it out of the socket. Now we need to find the ABS diagnostic connector. This is where I struggled. All of the internet info says it's a blue connector under a seat, but that's just on US-spec vehicles. Rave says it's a 5-pin connector near the fuse box. But I coundn't find that either. I believe that earlier (pre-95) models used this, but later ones moved it to the main diagnostic connector. This is a 16-pin socket, located under the steering wheel, just above the clutch. You don't need to remove any trim panels to get to it - although you may want to pop out the panel it's mounted on - it's not immediately clear how the pins are numbered, so look at the colours of the wires. The 2 pins we're interested in are pin4 (black) - ground, and pin15 (red/green) which goes to the ABS unit. If the internet sources are to be believed, the abs diagnostic wire may be black/pink on some models, and on the 5-pin connector we're interested in pins 2 and 5. But this has not been verified. You need some way of bridging the 2 pins. A paper clip or a piece of solid-core wire is ideal. Now, we're ready to go. Make sure the relay is disconnected. Turn on the ignition. The ABS warning light should come on, as usual. Bridge the 2 pins on the diagnostic conector. After 5 seconds, the ABS warning light should go out. It will then flash a pattern. From this, we can obtain the 2-digit fault code. first of all there will be 2 slow flashes - one longer than the other, with a gap of about 2 seconds. Then the interesting bit. The lamp will then flash, at about one flash per second. Count these flashes - that's your first digit. Then a pause Then it will flash out the second digit. This sequence will then repeat indefinitely (start, digit 1, digit 2). If you disconnect the link when the lights are flashing, it will clear the fault. Reconnecting it will show the next stored fault. If you have patience, you can read out and clear the entire contents of the ABS memory. In my case, all of the stored fault codes were the same - 2 flashes, then 12 flashes. So you look up 2-12 in the table below, and find "air gap, right hand front wheel speed sensor." This ties in with my own experience - I know that re-seating that sensor will temporarily cure my fault! Hope that someone finds this information useful. Bruce. The following table was obtained from http://www.bba-reman.com/content.aspx?c ... tification Fault Code Fault location 1-1 At start of sequence 2-6 (BPP)Brake pedal position switch 2-7 In system relay, when ignition is off the ECU supply is continuous. 2-8 In system relay, there is no solenoid valve supply. 2-12 Is an air gap, right hand front wheel speed sensor. 2-13 Is an air gap, left hand rear wheel speed sensor. 2-14 Is an air gap, left hand front wheel speed sensor. 2-15 Is an air gap, right hand rear wheel speed sensor 3-0 The ECU connection/wiring to right hand front inlet, hydraulic modulator solenoid valve. 3-1 The ECU connection or wiring to right hand front outlet, hydraulic modulator solenoid valve. 3-2 The ECU connection or wiring to left hand front inlet, hydraulic modulator solenoid valve. 3-3 The ECU connection or wiring to left hand front outlet, hydraulic modulator solenoid valve. 3-4 The ECU connection or wiring to right hand rear inlet, hydraulic modulator solenoid valve. 3-5 The ECU connection or wiring to right hand rear outlet, hydraulic modulator solenoid valve. 3-6 The ECU connection or wiring to left hand rear inlet, hydraulic modulator solenoid valve. 3-7 The ECU connection or wiring to left hand rear outlet, hydraulic modulator solenoid valve. 3-8 The ECU connection or wiring to inlet, isolating, hydraulic modulator solenoid valve. 3-9 The ECU connection or wiring to outlet, isolating, hydraulic modulator solenoid valve. 4-0 The ECU connection or short circuit to right hand front inlet, hydraulic modulator solenoid valve.(HMSV) 4-1 The ECU connection or short circuit to right hand front outlet, HMSV. 4-2 The ECU connection or short circuit to left hand front inlet, HMSV. 4-3 The ECU connection or short circuit to left hand front outlet, HMSV. 4-4 The ECU connection or short circuit to right hand rear inlet, HMSV. 4-5 The ECU connection or short circuit to right hand rear outlet, HMSV. 4-6 The ECU connection or short circuit to left hand rear inlet, HMSV. 4-7 The ECU connection or short circuit to left hand rear outlet, HMSV. 4-8 The ECU connection or short circuit to inlet, isolating, HMSV. 4-9 The ECU connection or short circuit to outlet, isolating, HMSV. 5-0 The ECU or solenoid valve supply short circuit to right hand front inlet, HMSV. 5-1 The ECU or solenoid valve supply short circuit to right hand front outlet, HMSV. 5-2 The ECU or solenoid valve supply short circuit to left hand front inlet, HMSV. 5-3 The ECU or solenoid valve supply short circuit to left hand front outlet, HMSV. 5-4 The ECU or solenoid valve supply short circuit to right hand rear inlet, HMSV. 5-5 The ECU or solenoid valve supply short circuit to right hand rear outlet, HMSV. 5-6 The ECU or solenoid valve supply short circuit to left hand rear inlet, HMSV. 5-7 The ECU or solenoid valve supply short circuit to left hand rear outlet, HMSV. 5-8 The ECU or solenoid valve supply short circuit to inlet, isolating, HMSV. 5-9 The ECU or solenoid valve supply short circuit to outlet, isolating, HMSV. 5-12 Sensor or wiring on right hand front wheel speed sensor. 5-13 Sensor or wiring on left hand rear wheel speed sensor. 5-14 Sensor or wiring on left hand front wheel speed sensor. 5-15 Sensor or wiring on right hand rear wheel speed sensor. 6-0 Short circuit of two ECU or solenoid connections to right hand front inlet, HMSV. 6-1 Short circuit of two ECU/ solenoid connections to right hand front outlet, HMSV. 6-2 Short circuit of two ECU or solenoid connections to left hand front inlet, HMSV. 6-3 Short circuit of two ECU or solenoid connections to left hand front outlet, HMSV. 6-4 Short circuit of two ECU or solenoid connections to right hand rear inlet, HMSV. 6-5 Short circuit of two ECU or solenoid connections to right hand rear outlet, H MSV. 6-6 Short circuit of two ECU or solenoid connections to left hand rear inlet, HMSV. 6-7 Short circuit of two ECU or solenoid connections to left hand rear outlet, HMSV. 6-8 Short circuit of two ECU or solenoid connections to inlet, isolating, HMSV. 6-9 Short circuit of two ECU or solenoid connections to outlet, isolating, HMSV. 6-12 Is no output or an air gap with right hand front wheel speed sensor. 6-13 Is no output or a large air gap with left hand rear wheel speed sensor. 6-14 Is no output or a large air gap with left hand front wheel speed sensor. 6-15 Is no output or a large air gap with right hand rear wheel speed sensor Quote Link to comment Share on other sites More sharing options...
stevegibbs Posted March 8, 2010 Author Share Posted March 8, 2010 This is the one I used (copied from the DOC forum) The ABS ECU itself is a standard Bosch/Wabco part. If you do some googling, you'll find that the same techniques and codes apply to many other vehicles that use this unit. First of all, we need to find the ABS warning light relay. On mine, it's in the passenger footwell, under the glove compartment. Lever out the 3 press-in studs, and the trim panel can drop. There are half a dozen relays in there. The one we're looking for is (on mine!) nearest to you, but in the second row, "behind" some others. Difficult to explain, but obvious when you get in there. The relay bases slide onto brackets, push them about an inch "away from the wires" and they'll come free. The one we're looking for has a green base, and has 2 black wires, 1 black/green wire and 1 brown/red wire. Disconnect this relay - pull it out of the socket. Now we need to find the ABS diagnostic connector. This is where I struggled. All of the internet info says it's a blue connector under a seat, but that's just on US-spec vehicles. Rave says it's a 5-pin connector near the fuse box. But I coundn't find that either. I believe that earlier (pre-95) models used this, but later ones moved it to the main diagnostic connector. This is a 16-pin socket, located under the steering wheel, just above the clutch. You don't need to remove any trim panels to get to it - although you may want to pop out the panel it's mounted on - it's not immediately clear how the pins are numbered, so look at the colours of the wires. The 2 pins we're interested in are pin4 (black) - ground, and pin15 (red/green) which goes to the ABS unit. If the internet sources are to be believed, the abs diagnostic wire may be black/pink on some models, and on the 5-pin connector we're interested in pins 2 and 5. But this has not been verified. You need some way of bridging the 2 pins. A paper clip or a piece of solid-core wire is ideal. Now, we're ready to go. Make sure the relay is disconnected. Turn on the ignition. The ABS warning light should come on, as usual. Bridge the 2 pins on the diagnostic conector. After 5 seconds, the ABS warning light should go out. It will then flash a pattern. From this, we can obtain the 2-digit fault code. first of all there will be 2 slow flashes - one longer than the other, with a gap of about 2 seconds. Then the interesting bit. The lamp will then flash, at about one flash per second. Count these flashes - that's your first digit. Then a pause Then it will flash out the second digit. This sequence will then repeat indefinitely (start, digit 1, digit 2). If you disconnect the link when the lights are flashing, it will clear the fault. Reconnecting it will show the next stored fault. If you have patience, you can read out and clear the entire contents of the ABS memory. In my case, all of the stored fault codes were the same - 2 flashes, then 12 flashes. So you look up 2-12 in the table below, and find "air gap, right hand front wheel speed sensor." This ties in with my own experience - I know that re-seating that sensor will temporarily cure my fault! Hope that someone finds this information useful. Bruce. The following table was obtained from http://www.bba-reman.com/content.aspx?c ... tification Fault Code Fault location 1-1 At start of sequence 2-6 (BPP)Brake pedal position switch 2-7 In system relay, when ignition is off the ECU supply is continuous. 2-8 In system relay, there is no solenoid valve supply. 2-12 Is an air gap, right hand front wheel speed sensor. 2-13 Is an air gap, left hand rear wheel speed sensor. 2-14 Is an air gap, left hand front wheel speed sensor. 2-15 Is an air gap, right hand rear wheel speed sensor 3-0 The ECU connection/wiring to right hand front inlet, hydraulic modulator solenoid valve. 3-1 The ECU connection or wiring to right hand front outlet, hydraulic modulator solenoid valve. 3-2 The ECU connection or wiring to left hand front inlet, hydraulic modulator solenoid valve. 3-3 The ECU connection or wiring to left hand front outlet, hydraulic modulator solenoid valve. 3-4 The ECU connection or wiring to right hand rear inlet, hydraulic modulator solenoid valve. 3-5 The ECU connection or wiring to right hand rear outlet, hydraulic modulator solenoid valve. 3-6 The ECU connection or wiring to left hand rear inlet, hydraulic modulator solenoid valve. 3-7 The ECU connection or wiring to left hand rear outlet, hydraulic modulator solenoid valve. 3-8 The ECU connection or wiring to inlet, isolating, hydraulic modulator solenoid valve. 3-9 The ECU connection or wiring to outlet, isolating, hydraulic modulator solenoid valve. 4-0 The ECU connection or short circuit to right hand front inlet, hydraulic modulator solenoid valve.(HMSV) 4-1 The ECU connection or short circuit to right hand front outlet, HMSV. 4-2 The ECU connection or short circuit to left hand front inlet, HMSV. 4-3 The ECU connection or short circuit to left hand front outlet, HMSV. 4-4 The ECU connection or short circuit to right hand rear inlet, HMSV. 4-5 The ECU connection or short circuit to right hand rear outlet, HMSV. 4-6 The ECU connection or short circuit to left hand rear inlet, HMSV. 4-7 The ECU connection or short circuit to left hand rear outlet, HMSV. 4-8 The ECU connection or short circuit to inlet, isolating, HMSV. 4-9 The ECU connection or short circuit to outlet, isolating, HMSV. 5-0 The ECU or solenoid valve supply short circuit to right hand front inlet, HMSV. 5-1 The ECU or solenoid valve supply short circuit to right hand front outlet, HMSV. 5-2 The ECU or solenoid valve supply short circuit to left hand front inlet, HMSV. 5-3 The ECU or solenoid valve supply short circuit to left hand front outlet, HMSV. 5-4 The ECU or solenoid valve supply short circuit to right hand rear inlet, HMSV. 5-5 The ECU or solenoid valve supply short circuit to right hand rear outlet, HMSV. 5-6 The ECU or solenoid valve supply short circuit to left hand rear inlet, HMSV. 5-7 The ECU or solenoid valve supply short circuit to left hand rear outlet, HMSV. 5-8 The ECU or solenoid valve supply short circuit to inlet, isolating, HMSV. 5-9 The ECU or solenoid valve supply short circuit to outlet, isolating, HMSV. 5-12 Sensor or wiring on right hand front wheel speed sensor. 5-13 Sensor or wiring on left hand rear wheel speed sensor. 5-14 Sensor or wiring on left hand front wheel speed sensor. 5-15 Sensor or wiring on right hand rear wheel speed sensor. 6-0 Short circuit of two ECU or solenoid connections to right hand front inlet, HMSV. 6-1 Short circuit of two ECU/ solenoid connections to right hand front outlet, HMSV. 6-2 Short circuit of two ECU or solenoid connections to left hand front inlet, HMSV. 6-3 Short circuit of two ECU or solenoid connections to left hand front outlet, HMSV. 6-4 Short circuit of two ECU or solenoid connections to right hand rear inlet, HMSV. 6-5 Short circuit of two ECU or solenoid connections to right hand rear outlet, H MSV. 6-6 Short circuit of two ECU or solenoid connections to left hand rear inlet, HMSV. 6-7 Short circuit of two ECU or solenoid connections to left hand rear outlet, HMSV. 6-8 Short circuit of two ECU or solenoid connections to inlet, isolating, HMSV. 6-9 Short circuit of two ECU or solenoid connections to outlet, isolating, HMSV. 6-12 Is no output or an air gap with right hand front wheel speed sensor. 6-13 Is no output or a large air gap with left hand rear wheel speed sensor. 6-14 Is no output or a large air gap with left hand front wheel speed sensor. 6-15 Is no output or a large air gap with right hand rear wheel speed sensor Many thanks for this you were right about trying to find the com.plug but i did, it is blue and was well hidden just above the brake pedel. If i ever meet you i owe you a beer. Quote Link to comment Share on other sites More sharing options...
