optixelectrics Posted March 5, 2010 Share Posted March 5, 2010 Hi All, I am looking to extend the breathers on my 200TDI and wondered if I could drill the airbox and run the extended 6mm pipes from the axles, gearbox and transfer box into that (obviously with the dowty seals, etc to keep it air/water tight). Then I could just add the snorkel at a later date. Cheers!! Quote Link to comment Share on other sites More sharing options...
jmattley Posted March 5, 2010 Share Posted March 5, 2010 Don't see why not, that's what I plan to do when I get round to it, as long as you seal the hole it'll be rate. That's what most people do. Quote Link to comment Share on other sites More sharing options...
sutty_32 Posted March 6, 2010 Share Posted March 6, 2010 How deep are you planning to go without a snorkel? The breathers usually sit at the back of the engine and should be fine in "normal" water, not that putting them in the air box would cause any problems Quote Link to comment Share on other sites More sharing options...
