defender dinky Posted March 10, 2010 Share Posted March 10, 2010 hi all, d90 1987 200tdi disco engine in it, went out this morning driving along about half hour, parked up went back to d90 started up driving a long reached a speed to change into 2nd a grinding noise appeared all through 2nd 3rd and 4th, as soon as i released off the pedal stopped back on grinding, back off stopped only when i use the gas,sounds like it's coming from middle of the floor in the back of the van, on rebuild i filled axles up, greased props t/box and gearbox all new oil, they had all been standing empty for about 3 weeks, now oil as circulated round parts could it be just need topping up, the noise only occurr's when i use acelorator pedal, things to check please starting with easist cheapest defender dinky Quote Link to comment Share on other sites More sharing options...
nicks90 Posted March 10, 2010 Share Posted March 10, 2010 i'd put money on diff pinion bearing worn out on the back diff. Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted March 10, 2010 Share Posted March 10, 2010 Yep, that'll be a diff on its way out. It happened to me in December, sheared the whole pinion shaft. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted March 10, 2010 Author Share Posted March 10, 2010 Yep, that'll be a diff on its way out. It happened to me in December, sheared the whole pinion shaft. hi, i have a spare axle here but it's off a disco would the diff be the same, defender dinky Quote Link to comment Share on other sites More sharing options...
zulublue Posted March 10, 2010 Share Posted March 10, 2010 Diff should go straight on, you probably have drum rear brakes so it may be worth swapping the whole axel to give you disc all around. not much extra work. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted March 10, 2010 Author Share Posted March 10, 2010 Diff should go straight on, you probably have drum rear brakes so it may be worth swapping the whole axel to give you disc all around. not much extra work. hi, already done disc conversion, had axle sandblasted painted, so just want to change diff really, just a thought went under landy this afternoon guess what nuts were lose on front prop by axle could this be the noise i was hearing, take the landy out in the morning find out more, thanks for replies, defender dinky Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted March 10, 2010 Share Posted March 10, 2010 The diff will go straight on, its just a matter 10 bolts. The drive flange is different though. Quote Link to comment Share on other sites More sharing options...
