tedsy Posted March 12, 2010 Share Posted March 12, 2010 I have a 95 300 TDI Discovery. Im going to service it this weekend so I have got out my best hammer and a new tin of WD40. From what Ive read everything looks pretty straightforward. One question I have is how do I know if I have have one shot grease in the swivel hubs or not. Im guessing if I have a grease nipple showing then not? All abusive replies and suggestions are welcome.# Cheers Mark Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 12, 2010 Share Posted March 12, 2010 No grease nipple as standard I'm afraid - one shot cones in a sachet that you squeeze through the filler plug. To check what you have in there - remove the filler plug and 'dip' a straw or bit of wire in there. One shot is dark grey and quite thick. Les. Quote Link to comment Share on other sites More sharing options...
bobtail4x4 Posted March 12, 2010 Share Posted March 12, 2010 The garages were "supposed" to paint the filler plug yellow to show it had grease in. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted March 14, 2010 Share Posted March 14, 2010 The grease wasn't around in 1995, so your Disco had oil in it at the start. If you look, you will have three plugs on the swivel housings - a drain at the bottom, a level plug in the middle and a filler plug at the top. Take out the drain plug and see what comes out.... If your seals are in good nick you are better off with the oil IMHO. I still use oil in my 95 Defender. After all, you don't fill your gearbox with grease, do you? The grease is a typical LR bodge-up to get over a design failing. Quote Link to comment Share on other sites More sharing options...
bobtail4x4 Posted March 14, 2010 Share Posted March 14, 2010 Im sure I used grease in my first Range Rover in the mid 90s. anyway take the drain plug out and see whats in. Quote Link to comment Share on other sites More sharing options...
tedsy Posted March 28, 2010 Author Share Posted March 28, 2010 Well thanks for all the help. It turns out the filler plug was painted yellow. Dipped some wire in to make sure and there definately wasnt any oil in there. Thanks again Cheers Mark Quote Link to comment Share on other sites More sharing options...
