Glennie Posted March 13, 2010 Share Posted March 13, 2010 hi, having a problem starting my 1998 freelander.i unlock the car as normal, no problem.... put the key into the ignition and turn it on and wait for the normal lights on the dashboard to go out.turning the key to start the car nothing happens...after a few attemps it will start. can anyone help. Quote Link to comment Share on other sites More sharing options...
Sputnik 1 Posted March 14, 2010 Share Posted March 14, 2010 Might sound daft but I had a similar problem with mine - all I did was change the battery in the keyfob and it hasnt done it since....... Quote Link to comment Share on other sites More sharing options...
Glennie Posted March 14, 2010 Author Share Posted March 14, 2010 thanks for replying, i changed the batteries the other day,i was hoping that would work but it didn't.do you think it might be the ignition barrel? Quote Link to comment Share on other sites More sharing options...
v8bertha Posted March 14, 2010 Share Posted March 14, 2010 I had this for a while on my defender... it turned out I had a sticky starter relay. I know its a completely different vehicle and I have no idea if the Freelander setup is similar or not, but it may give you another avenue of investigation if the obviose hasn't solved your problem. Quote Link to comment Share on other sites More sharing options...
Glennie Posted March 15, 2010 Author Share Posted March 15, 2010 I had this for a while on my defender... it turned out I had a sticky starter relay. I know its a completely different vehicle and I have no idea if the Freelander setup is similar or not, but it may give you another avenue of investigation if the obviose hasn't solved your problem. thanks very much for your input,i have someone looking at it on 16-3-10, and i will put that to him, fingers crossed,i will let you know the out come many thanks. Quote Link to comment Share on other sites More sharing options...
Glennie Posted March 17, 2010 Author Share Posted March 17, 2010 thanks very much for your input,i have someone looking at it on 16-3-10, and i will put that to him, fingers crossed,i will let you know the out come many thanks. had a guy out to fix my car,i had mentioned about the sticky starter relay, which he checked and was seen to be ok.in the end it was the ignition switch,so i have my beloved lanny on the road again. thanks very much for your help Quote Link to comment Share on other sites More sharing options...
