88inchthing Posted March 14, 2010 Share Posted March 14, 2010 Hi all The oil light has just started coming on at idle on my 200tdi powered series3. I seem to recall reading somthing on a forum about a core plug that works loose (pressumably on the main oil gallery)? Just wondered if this rings a bell with any one. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 15, 2010 Share Posted March 15, 2010 I'd suggest you replace the sender - they get weak over time and give a false reading. Les. Quote Link to comment Share on other sites More sharing options...
88inchthing Posted March 15, 2010 Author Share Posted March 15, 2010 I'd suggest you replace the sender - they get weak over time and give a false reading. Les. Thanks Les,I now recall it was a cam bearing that can move and cause oil pressure to drop. First port of call will be the oil pressure switch as you suggest. Bill Quote Link to comment Share on other sites More sharing options...
