Retroanaconda Posted March 14, 2010 Share Posted March 14, 2010 I'm rebuilding an early Disco rear axle of 1991 (H) vintage, which I have put under the back of my 90, and one of the stub axles is a bit worse for wear, so I am wondering to myself...will one of the stubs from the original drum-braked 1992 axle fit in it's place? The part numbers are different, but they both use the 'flat side' location method rather than the 'peg' method, and they both originally had those silly outer seals and rubber-lined track spacers (which I'll be changing for the later inner-seal-only and thrust washer setup), so I'm thinking they should fit? Can anyone confirm either way? Quote Link to comment Share on other sites More sharing options...
KKMobile Posted March 14, 2010 Share Posted March 14, 2010 I'm rebuilding an early Disco rear axle of 1991 (H) vintage, which I have put under the back of my 90, and one of the stub axles is a bit worse for wear, so I am wondering to myself...will one of the stubs from the original drum-braked 1992 axle fit in it's place? The part numbers are different, but they both use the 'flat side' location method rather than the 'peg' method, and they both originally had those silly outer seals and rubber-lined track spacers (which I'll be changing for the later inner-seal-only and thrust washer setup), so I'm thinking they should fit? Can anyone confirm either way? I would say if all the measurements are the same go for it?? Quote Link to comment Share on other sites More sharing options...
