Marks 110 Posted April 2, 2010 Share Posted April 2, 2010 I have an injection pump which came with a spare 200tdi engine I bought for the defender. The engine is from a disco. Just wondering if the pump would work with the original defender set up or would it need the discovery turbo as well. Mark Quote Link to comment Share on other sites More sharing options...
western Posted April 2, 2010 Share Posted April 2, 2010 You can use the Disco FIP on your Defender tdi engine.don't need the Disco turbo. Quote Link to comment Share on other sites More sharing options...
Marks 110 Posted April 2, 2010 Author Share Posted April 2, 2010 You can use the Disco FIP on your Defender tdi engine.don't need the Disco turbo. Great, I'll keep it as spare. Will it need any ajustments or just fit straight on? Cheers Mark Quote Link to comment Share on other sites More sharing options...
western Posted April 2, 2010 Share Posted April 2, 2010 it should fit straight on, but will need adjusting/timing as per changing a timing belt change. Quote Link to comment Share on other sites More sharing options...
RaDi90Hybrid Posted April 2, 2010 Share Posted April 2, 2010 The Disco turbo won't fit the Defender, it is a Landrover and that would be far too easy. IIRC the only bit which is usable is the spinner inside. Andy Quote Link to comment Share on other sites More sharing options...
