jmattley Posted April 3, 2010 Share Posted April 3, 2010 The cambelt snapped yesterday on my 200tdi, i was doing about 30 at the time and stopped straight away so I didn't drive far with it broken. My question is, will it just be a case of a couple of bent push rods and dented valves or will there be much more damage done to the engine? Cheers everyone!!! Quote Link to comment Share on other sites More sharing options...
western Posted April 3, 2010 Share Posted April 3, 2010 valves & pistons are square to eachother, so they should be OK, check the pushrods by rolling on a known flat surface, probably best to replace all 8 pushrods, hopefully that will be all but check the rockers/valve cap shims & rocker shaft for any damage. Quote Link to comment Share on other sites More sharing options...
