white90 Posted May 7, 2006 Share Posted May 7, 2006 Transfer box can be lifted on and off by hand from underneath. Some long studs can help - get 4 180mm M10 bolts and chop the heads off, I then cut a slot in the cut end to use a flat blade screw driver in them. Put these in the rear 4 holes that you remove the bolts from that hold the transfer box to the main box. Slide the transfer box off along these bolts. Then when fitting these bolts help guide the transfer box back into place, just a little jiggle of an output flange (don't forget diff lock) to line the splines up and it'll pop right on Link to comment Share on other sites More sharing options...
white90 Posted June 5, 2006 Author Share Posted June 5, 2006 Here for pics Link to comment Share on other sites More sharing options...
