negativepitch Posted April 8, 2010 Share Posted April 8, 2010 hello chaps, I would like to stick a stainless steel exhaust tip on my TD4 facelift 06 sport, not having a clue what to look for, has anyone got any links etc to some, as I would just like to tidy up the back end a bit...well in my eyes anyways cheers for any help steve. Quote Link to comment Share on other sites More sharing options...
LR NUT Posted April 9, 2010 Share Posted April 9, 2010 Most tail pipe finishers are designed for a car and therefore the tail pipe will be a smaller diameter to your freelander exhaust pipe. After ensuring that you have a tail pipe which is of a larger diameter to your exhaust pipe, you would be best to cut the curve of the exhaust pipe so that the tail pipe finsher sits straight and doesnt point down. Take your time in doing this and dont cut the exhaust too far back as then the fumes may find the way into the cabin. Finally you will need to drill a hole in the exhaust in order to secure the tail pipe via the nut and bult supplied with the tail pipe finisher. Quote Link to comment Share on other sites More sharing options...
negativepitch Posted April 10, 2010 Author Share Posted April 10, 2010 many thanks for the advice, somthing for me to go off, cheers. Most tail pipe finishers are designed for a car and therefore the tail pipe will be a smaller diameter to your freelander exhaust pipe. After ensuring that you have a tail pipe which is of a larger diameter to your exhaust pipe, you would be best to cut the curve of the exhaust pipe so that the tail pipe finsher sits straight and doesnt point down. Take your time in doing this and dont cut the exhaust too far back as then the fumes may find the way into the cabin. Finally you will need to drill a hole in the exhaust in order to secure the tail pipe via the nut and bult supplied with the tail pipe finisher. Quote Link to comment Share on other sites More sharing options...
mudcrawler Posted April 10, 2010 Share Posted April 10, 2010 Is this what you're looking for? Found it on eBay! Freelander Exhaust Trim Quote Link to comment Share on other sites More sharing options...
negativepitch Posted April 10, 2010 Author Share Posted April 10, 2010 top man !! cheers for the link matey... steve. Is this what you're looking for? Found it on eBay! Freelander Exhaust Trim Quote Link to comment Share on other sites More sharing options...
mudcrawler Posted April 10, 2010 Share Posted April 10, 2010 Any time mate! Glad to be of service! Quote Link to comment Share on other sites More sharing options...
