ouchie Posted April 23, 2010 Share Posted April 23, 2010 has any one out there changed the fuel pipe cluster on a disco td5 and can it be done with the tank on ???. Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted April 23, 2010 Share Posted April 23, 2010 has any one out there changed the fuel pipe cluster on a disco td5 and can it be done with the tank on ???. Yes its just a little tricky over the top of the chassis.....make sure you cap the ends of all pipes until there in place. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 23, 2010 Share Posted April 23, 2010 It would be a nightmare to get the pipes routed correctly and clipped to the rear tank crossmember - I wouldn't even contemplate it. The pipes have to be routed exactly right, or they will rub on various metal components and eventually leak. There was a recall on the TD5 Disco's because of this - one pipe rubbing on the chassis and eventually leaking. I strongly advise you to drop the tank and do it 'properly' or you will regret it. Thread on one I did here - http://forums.lr4x4....showtopic=23450 Les. Quote Link to comment Share on other sites More sharing options...
Guest MRPLEBBY Posted April 23, 2010 Share Posted April 23, 2010 I had a major leak done on mine under warranty, i was told it was another common fault where the pipe rubs and wears, the diesel was squirting all over the rear window. Quote Link to comment Share on other sites More sharing options...
ouchie Posted April 24, 2010 Author Share Posted April 24, 2010 thanks les thats what i will do i did already view your topic but thanks for the link as i look out my window my new garage is under construction,so a think that will be the first job.at 4 mtrs wide and 7 long it will be just the place . Quote Link to comment Share on other sites More sharing options...
