Full width intercoolers
disco_al
Here you go
Assumimg its for a disco 300tdi
320mm x 500mm x 60mm core size
610mm total outer width
330mm height
65mm thick
51mm inlet tube diameter
51mm outlet tube diameter
M8 front mounting bosses
As for air con you would have to speak to Andrew at Allisport as im sure it can be done :D
does anyone know the dimensions of the allisport full width intercoolers, and also if it is possible to make one fit with the air con still in place?
Can`t tell you the size off hand. But i have one on the wifes Disco 300 and thats got Aircon in situ, and yes its the Allisport one
Regards
Keith.
