adambowling Posted April 26, 2010 Share Posted April 26, 2010 Hi I've just replaced front drivers hub, stub axle and bearing only to find a knocking when on full lock turning right. I have been advised that it is the cv joint. How do I change this? Is it a big job to do, expensive and time consuming? Cheers Adam Quote Link to comment Share on other sites More sharing options...
white90 Posted April 26, 2010 Share Posted April 26, 2010 Tech Archive has this in the How to with Henson axle section Dependant on which brand you buy will affect costs If you replaced the stub axle there is nothing to it really. the CV is inside the stub axle so just remove that to gain access. Quote Link to comment Share on other sites More sharing options...
errol209 Posted April 26, 2010 Share Posted April 26, 2010 Tech Archive has this in the How to with Henson axle section Tony, I think I'm going blind - I was looking for a "Les" for another thread, and I can't find it? Where's it hiding ? Quote Link to comment Share on other sites More sharing options...
white90 Posted April 26, 2010 Share Posted April 26, 2010 http://forums.lr4x4.com/index.php?showtopic=5601 covers it Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted April 26, 2010 Share Posted April 26, 2010 Hi I've just replaced front drivers hub, stub axle and bearing only to find a knocking when on full lock turning right. I have been advised that it is the cv joint. How do I change this? Is it a big job to do, expensive and time consuming? Cheers Adam This actually means "My mate has done it all for me for a pint" CV wont be hard, ive never done it... but as its your truck, i dont care if i break something Quote Link to comment Share on other sites More sharing options...
