Changing a CV
adambowling
Tech Archive has this in the How to with Henson axle section
Dependant on which brand you buy will affect costs
If you replaced the stub axle there is nothing to it really.
the CV is inside the stub axle so just remove that to gain access.
Guest noggy
Hi
I've just replaced front drivers hub, stub axle and bearing only to find a knocking when on full lock turning right.
I have been advised that it is the cv joint.
How do I change this?
Is it a big job to do, expensive and time consuming?
Cheers
Adam
This actually means "My mate has done it all for me for a pint"
CV wont be hard, ive never done it... but as its your truck, i dont care if i break something :D
