trt1617 Posted April 26, 2010 Share Posted April 26, 2010 evening all i have posted on here about a steering box leak and found out i have a six bolt steering box on my 90 just wondered if any other box will fit? are there any beter than others? and can any be swapped between models? ie disco to 90? any info would be helpful many thanks Quote Link to comment Share on other sites More sharing options...
white90 Posted April 26, 2010 Share Posted April 26, 2010 The others will fit but you have to renew the pipes 4bolt is the preferred if you fancy a change Quote Link to comment Share on other sites More sharing options...
trt1617 Posted April 26, 2010 Author Share Posted April 26, 2010 The others will fit but you have to renew the pipes 4bolt is the preferred if you fancy a change if only id taken the one off the disco i used as the donor could have used the drop arm and steering arms as well Quote Link to comment Share on other sites More sharing options...
