defender dinky Posted April 27, 2010 Share Posted April 27, 2010 hi all, had a steering problem for a while now, got a couple of days off so why not have ago, right, bled it to no avail, new balljoints still the same,drop arm was leaking change pas box still same,now today i took off tackrods, drag linkwith the damper on, passenger wheel moves freely, but driver's side ok until it straightens upthen it feels as if it's snagging on something really bad, done preload set at 3.60kg as in work manual, anybody got the answere asap cheer's defender dinky Quote Link to comment Share on other sites More sharing options...
errol209 Posted April 27, 2010 Share Posted April 27, 2010 but driver's side ok until it straightens upthen it feels as if it's snagging on something really bad, done preload set at 3.60kg as in work manual, anybody got the answere asap cheer's defender dinky Did you do the swivel pin bearings too? Sounds like one might be sticking. Watch with Les Quote Link to comment Share on other sites More sharing options...
defender dinky Posted April 27, 2010 Author Share Posted April 27, 2010 Did you do the swivel pin bearings too? Sounds like one might be sticking. Watch with Les Quote Link to comment Share on other sites More sharing options...
defender dinky Posted April 27, 2010 Author Share Posted April 27, 2010 hi thanks but have found the problem it was the cv joint cheers dd Quote Link to comment Share on other sites More sharing options...
