Safari Snorkel fitting instruction
Niamh
The 300TDi instructions say for the inner wing hole location- "To mark the inside hole position, measure down from the inner guard lip 72mm and forward from the firewall 310mm. Re-check these measurements several times until the positions intersect in the same place."
What exactly to they mean by the inner guard lip and the firewall? A diagram would have been so much clearer!
Niamh
I think the firewall is the bulkhead, and the inner guard lip perhaps the top of the inner wing? I wasn't too sure when i did mine so I cut the outside wing first and then held the snorkel in position, had to make the hole a little bigger but it wasn't a bad guess! It is also inside and the rubber trim bit still makes it look quite neat.
basically if you look on the n/s inner wing you will see a big round pressing mark, that's roughly where you need to cut the inner hole. On 200 tdi's that's where the air intake is...
And on 300TDIs that's obstructed by the airbox, so the hole must go a good bit further back.
Niamh
  • 2 weeks later...
