bm52 Posted May 2, 2010 Share Posted May 2, 2010 Hi i have a very standard 90 300tdi which needs new bushes on the rear shocks - MOT advisory. it has been waxoiled and everything is covered in it. any idea how i can tell what's on there? i am assuming they are just standard LR shocks but it does bounce a bit unladen at the back at times so i was wondering if they are hard shocks. 4 x 6footers in the rear and the back drops about 2 inches to give you an idea. the ride is fine, does'nt lean much on corners and drives very well so i don't want to ruin the set-up. also - there is no sign of drop/sag at the back or the front so can i just replace the shocks? thanks Quote Link to comment Share on other sites More sharing options...
scube Posted May 16, 2010 Share Posted May 16, 2010 If it drives well, doesn’t lean much in the corners etc etc You could just replace the bushes Top NRC5593 x 2 Bottom RNF100090L x 4 STD rear shocks are STC3767 x 2 Or go for an upgrade and fit gas shocks. No right or wrong option it a matter of choice. Quote Link to comment Share on other sites More sharing options...
