Bigant Posted May 7, 2010 Share Posted May 7, 2010 Dear All I have finally got the series 2a out of winter storage and for some reason there is no fuel getting to the carb so obviously she won't start. I have removed and cleaned the mechanical fuel pump with no luck, so I have now changed it for one I had knocking around and I still can't get fuel out of the tank. I have drained the fuel tank and filled up with fresh fuel just to be safe. If anyone has any idea's on what I should try next or indeed what I need to do to the fuel pump to start getting the fuel through to the carb I will be most grateful. Thanks for your time Bigant Quote Link to comment Share on other sites More sharing options...
Rich_P Posted May 7, 2010 Share Posted May 7, 2010 If the lift pump won't draw fuel, you need to check that the pipework to the tank is okay. You may have a big air leak, so the pump will be drawing air rather than fuel. Quote Link to comment Share on other sites More sharing options...
kingdong2 Posted May 7, 2010 Share Posted May 7, 2010 Hi bigant do you have any dregs of petrol still in the can you used to fill the tank up if you do try emptying some into the carb and see if it will start, it may just be that the battery is starting to go flat before the fuel gets through the pump and to the carb. graham _________________ 03 d2 td5 auto e.s. 97 di 300 tdi man now sold. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted May 7, 2010 Share Posted May 7, 2010 It could be dry valves in the lift pump so they dont seal too well with the result that it wont draw the fuel. Have you tried hand pumping the lift pump to fill the carb. If it is dry valves a dodge i use is disconnect the inlet pipe and squirt some oil in the inlet and then give it a pump on the priming lever, if that makes the sucky noises sound correct refit the pipe and then pump the petrol up. Quote Link to comment Share on other sites More sharing options...
Bigant Posted May 8, 2010 Author Share Posted May 8, 2010 Hi all Thanks for the tips, rest assurred I will be trying them all to see if i can get her started, I will let you know how I get on. Cheers Bigant Quote Link to comment Share on other sites More sharing options...
