Swivel Pin removal
Wheel brake spindle cv & axle ball joint removed next to remove seal from swivel pin housing
Swivel pin removal (lower) description states removal by tapping protruding lug?
Tapping anyone give some direction on this.
87 D-90 xmod should be same as other models.
Best Craig states side
there should be a raised lug on the outer edge of the lower swivel pin in the ara I've ringed on a copy of your photo, give it a downwards tap with a copper or brass drift & decenr size hammer, put a rag or something under the swivel so the pin doesn't land on a hard surface.
 Share
