trickymicky Posted May 13, 2010 Share Posted May 13, 2010 I have a 200 tdi Defender. 100,000 miles. Today, i tried to start her up but she would fire but not run. I then noticed oil all over the n/s front chassis. I unclipped the air filter and saw the oil had been coming from the air filter drain. I took out the paper filter that was half soaked in oil and started her up with no problems. Apart from not starting that one time i have had no problems. No strange noises from the turbo, no lack of power, no smoke from the exhaust. She is running fine. I was wondering, are there any oil seals in the turbo? I can't think where else the oil could be coming from. Can anyone give me a clue? Quote Link to comment Share on other sites More sharing options...
KKMobile Posted May 13, 2010 Share Posted May 13, 2010 I would get it checked asap!! you don't want it to start running on it's own oil!!!! I had a 200tdi Disco engine in my defender when i first bought it! It started ok & run with no funny noises. Had it on the road less than a week, driving home after having some work done on it & it just stopped for no reason, but would turn over and try to run then stall. After investigation under the bonnet i noticed while trying to start the air pipe from intercooler to engine was sucking in. I.E no air. disconnected the pipe to find it had a fair bit of iol in it. The car started with pipe removed! got it home Cleaned / flushed all pipework & intercooler all ok. Then 3 days later just going out for a run it stalled again when approaching a roundabout with thick black / blue smoke comming from exhaust & raised air intake, would'nt start for love nor money even after diconecting the pipe i had done before. Got it towed home & removed head only to find bottom end sh@gged!! It had pressurised the sump forcing the oil up into air system etc. Not saying this is the same as yours!! As i'm not a trained mechanic with cert's etc. But something to beware of as you don't want oil getting in there!! Quote Link to comment Share on other sites More sharing options...
KKMobile Posted May 13, 2010 Share Posted May 13, 2010 Might be of interest / something to keep an eye on?? http://forums.lr4x4.com/index.php?showtopic=56256 Quote Link to comment Share on other sites More sharing options...
