mudmuncher Posted May 16, 2010 Share Posted May 16, 2010 Hi all got a baremach swingaway rear wheel carrier I have fitted it but a couple of things worry me It is working fine and opens and closes ok with the door problem is it seam to be stuck out from the landrover quite far eg quite a big gap between the wheel and the door also the spare wheel is sat at a angle to the right when you look at it from the back of the landrover Is this correct ??? Please help cheers chris Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 16, 2010 Share Posted May 16, 2010 Chris, can you stick up a couple of photos to show the problem ? Mo Quote Link to comment Share on other sites More sharing options...
