DAN82SED Posted May 18, 2010 Share Posted May 18, 2010 my 110 has heavy duty springs (standard high, i think) but the fact that it is never heavily ladened it appears to sit about an inch higher than standard. i do intend getting medium weight spings with a two inch lift but would my current setup do for the mean time??? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 18, 2010 Share Posted May 18, 2010 Technically speaking a spring lift should not affect tyre clearance as compression travel is limited (or should be) by the bump stops. Of course, many poorly designed spring lifts do limit compression travel. For a 33"x12.5, you need around another 1" or so taller bump stops in the rear and wheels with around 10mm of offset (normal aftermarket wheels). You may need a little trimming of the eyebrows as well dependent on the specific tyre. Keep in mind that Defenders are built to a tolerance of plus or minus an inch and you need to check clearance on your own truck.... Quote Link to comment Share on other sites More sharing options...
DAN82SED Posted May 18, 2010 Author Share Posted May 18, 2010 cheers red, bump stops shouldnt be an issue coz the springs r so stiff that my 110 would roll before bottoming out! off roading is at the moment is like being a pinball. think i get the wheels, if theres issues will just have to wait til next month to fit them {when i can afford the lift} Quote Link to comment Share on other sites More sharing options...
fekete Posted May 18, 2010 Share Posted May 18, 2010 Hi iv'e got 33/12.50/15 without any issues.......iv'e only got HD Springs on they will be fine Quote Link to comment Share on other sites More sharing options...
DAN82SED Posted May 18, 2010 Author Share Posted May 18, 2010 cheers fekete, thats what i was hoping to hear, did u have to fit extended wheel arches? or adjust the steering stops? Quote Link to comment Share on other sites More sharing options...
