stuckinthemud Posted May 23, 2010 Share Posted May 23, 2010 Aircon stopped working recently, worked out it was the high/low pressure cut-out sensor that was disabling the system so assumed that, after 11 years, the system needed a re-gas! One (garage) re-gas attempt with the proper kit, which failed saying the system had a leak. Any suggestions as to where I might start looking? Are there "usual suspects" that cause failures? Thanks Jim Quote Link to comment Share on other sites More sharing options...
Richard Mills Posted May 25, 2010 Share Posted May 25, 2010 Hi There. I had a leak to find, it is not easy. There are two ways. The proper way is to add a luminous dye to the air con fluid and look for staining with a UV light. With mine, I saw corrosion on the bottom corner of the air con's radiator. Cost me £85 for a replacement... Do it on a dry day to avoid getting damp into the system. Mine still leaks a bit, but a recharge from Halfords fixes it for a year. The recharge cans are £20 but have a £10 return deposit in them. God luck with it! Quote Link to comment Share on other sites More sharing options...
