bombx3 Posted May 24, 2010 Share Posted May 24, 2010 i am trying to sort out the low end power blow 2000rpm problem on my td5 changed using genuine parts filters air/fuel injector loom egr Maf fuel regulator took reading today and inlet pressure is at idle 100kpa and at 3450 206kpa at 3000rpm it reads 196 kp at 2062 120 kpa is this corrrect? Quote Link to comment Share on other sites More sharing options...
black-ibex Posted May 24, 2010 Share Posted May 24, 2010 Hi, From Nanocom data: AMBIENT PRESSURE(Kpa) – This value must be 100Kpa at the sea level and decrease when the ground height increases. A decreasing of that value related to the acceleration should indicate that the air beyond the filter is less than required. MANIFOLD TURBO PRESSURE(Kpa) – at idle speed must be equal to the ambient pressure 100Kpa and it goes up to 210 (Defender) or 230 (Discovery) at engine maximum load Hope this helps. Dave Quote Link to comment Share on other sites More sharing options...
bombx3 Posted May 24, 2010 Author Share Posted May 24, 2010 thanks for the quick reply i think my pressures are ok Quote Link to comment Share on other sites More sharing options...
SteveG Posted May 25, 2010 Share Posted May 25, 2010 Here's some test data when I was looking at my clutch slip issue, if it helps to give you some sample data. It's a 2005 TD5 90 with a remap. Files attached. Let me know if you want excel sheet e-mailed Quote Link to comment Share on other sites More sharing options...
