bigstevemex Posted May 24, 2010 Share Posted May 24, 2010 posted the other day no replies.anyone know where to get compression fitting to plumb in eberspacher heater to fuel line or just what size is needed?thanks steve Quote Link to comment Share on other sites More sharing options...
Guest Posted May 24, 2010 Share Posted May 24, 2010 Hi Steve, Not sure what you are trying to do, or what vehicle you have, that is maybe why you have had no replys... If you are trying to fit a Eberspacher D2 or similar into the fuel system this will not work as without the ignition on there will be no fuel, if you have a TD5 with the fuel pump in the tank there is a blank plug on it to fit the fuel pick up pipe into the tank, I can't find the post but I am sure a grown up on here will be able to find it for you it was complete with part numbers for the bits of pipe although you could make your own. Jason. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 25, 2010 Share Posted May 25, 2010 Normal fuel lines are 3/8" nylon on pre TD5. Read above wrt TD5. It would help if you told us what truck..... Quote Link to comment Share on other sites More sharing options...
