cluelesstoe Posted June 8, 2010 Share Posted June 8, 2010 are all classic chassis the same? Quote Link to comment Share on other sites More sharing options...
vougese39 Posted June 9, 2010 Share Posted June 9, 2010 no ealry ones have opposed shock mountings and a different gearbox crosss member latter ones have a different gearbox cross member and rear facing shocks apart from that nothing else as far as i know Quote Link to comment Share on other sites More sharing options...
Ragtag Posted June 10, 2010 Share Posted June 10, 2010 no ealry ones have opposed shock mountings and a different gearbox crosss member latter ones have a different gearbox cross member and rear facing shocks apart from that nothing else as far as i know If you imagine the cross section of the chassis rail, on the really early ones (maybe the first 2 years or so) the corners of the box had crisp sharp edges as opposed to radius corners. Quote Link to comment Share on other sites More sharing options...
p76rangie Posted June 10, 2010 Share Posted June 10, 2010 are all classic chassis the same? As stated, the early 2 door rangies had one rear shock facing the rear and the opposite side facing the front. When they went to air suspension in the early 90's they fitted extra bits. Also in the late 80's/early 90's they changed the gearbox cross member to a round one of different shape to the old square ones. The also changed the rear rear cross member, that the A frame fits to, to a round one with the A frame mounts built into it rather than bolted to the old spare ones. There are also a number of other changes like later model radiators mounted to the chassis, where the mid 80's ones mounted to the body, etc. Quote Link to comment Share on other sites More sharing options...
rocksteady Posted June 10, 2010 Share Posted June 10, 2010 Then they made the LSE 108in wb. Quote Link to comment Share on other sites More sharing options...
