kellyv8 Posted June 19, 2010 Share Posted June 19, 2010 ive just replaced the cylinder head on my 1995 discovery and while attempting to put it all back together ive discovered that the 10 new bolts in the head bolt set are 15mm shorter than the old ones which are the correct size at 140mm will i be able to still use these or are the bolts wrong Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 20, 2010 Share Posted June 20, 2010 I wouldn't - 15mm is a heck of a lot of thread that should be in the block and won't be. I would expect the difference between old and new to be 1mm or less. They are stretch bolts, but there's no way there would be that much variation. Perhaps you have been supplied the head bolts for another engine? Les. Quote Link to comment Share on other sites More sharing options...
kellyv8 Posted June 20, 2010 Author Share Posted June 20, 2010 cheers for the reply les, i did think the same thing but just wanted it confirmed, i did check if they posibly give me 200 tdi ones but i think they are all the same. looks like a trip back there on monday Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 20, 2010 Share Posted June 20, 2010 200TDi is - ETC8806 x 4 ETC8819 x 4 ETC8809 x 10 300TDi is - ETC8806 x 4 ETC8810 x 4 ERR1939 x 10 Les. Quote Link to comment Share on other sites More sharing options...
