keithjh Posted May 20, 2006 Share Posted May 20, 2006 Hi All, Having fitted the engine, box from a disco 300tdi auto into a 110, the pipes from the oil cooling rad are not fitting to well , so basically can i cut them then rejoin them with flexible hose, if so then does it need to be high pressure etc and if so where can i get it from with approprite clams clips etc. regards Keith Quote Link to comment Share on other sites More sharing options...
western Posted May 20, 2006 Share Posted May 20, 2006 Contact your local Pirtek centre, they deal with hydraulic/high pressure hoses every day & will extend or make new hoses using the existing end fittings. Pirtek there's a drop down menu to find your nearest centre/agent. Quote Link to comment Share on other sites More sharing options...
