TheTruckMan Posted June 20, 2010 Share Posted June 20, 2010 need the part number for the wired conector that plugs into the rear brake/talegate light as the prongs have snaped and brake light not working?? i have a defender 90 county 2001 Quote Link to comment Share on other sites More sharing options...
Landy'd Gentry Posted June 20, 2010 Share Posted June 20, 2010 Quick look: XFG100330 is the High level Brake like kit, available from Jon Craddocks* for £18.93 + vat & p+p, *(other suppliers are available) Hope this helps. Quote Link to comment Share on other sites More sharing options...
TheTruckMan Posted June 20, 2010 Author Share Posted June 20, 2010 Quick look: XFG100330 is the High level Brake like kit, available from Jon Craddocks* for £18.93 + vat & p+p, *(other suppliers are available) Hope this helps. thanks mate Quote Link to comment Share on other sites More sharing options...
Landy'd Gentry Posted June 20, 2010 Share Posted June 20, 2010 Pleased to be of assistance! Quote Link to comment Share on other sites More sharing options...
TheTruckMan Posted June 20, 2010 Author Share Posted June 20, 2010 just looked at them its not the part number i want. i mean the rear brake light small circular one, the conectors in the wire have snaped so the only part of the light that works is the rear light when i have my lights on it does not work when i brake??? Quote Link to comment Share on other sites More sharing options...
Landy'd Gentry Posted June 20, 2010 Share Posted June 20, 2010 Is this what you are after: AMR3334? part number AMR3334 has supeceeded STC1189 Quote Link to comment Share on other sites More sharing options...
Landy'd Gentry Posted June 20, 2010 Share Posted June 20, 2010 XDF100100 is the stoplight/tail light assembly Quote Link to comment Share on other sites More sharing options...
TheTruckMan Posted June 20, 2010 Author Share Posted June 20, 2010 do you know any websites i can look at the parts and order from? Quote Link to comment Share on other sites More sharing options...
TheTruckMan Posted June 20, 2010 Author Share Posted June 20, 2010 XDF100100 is the stoplight/tail light assembly found this one mate, do yo know if yo get the wires and conector or is this just for the shell Quote Link to comment Share on other sites More sharing options...
Landy'd Gentry Posted June 20, 2010 Share Posted June 20, 2010 According to the parts catalogue, there is also XBP100190 BULB HOLDER STOP TAIL 90/110 1994 TO TA9 75885 So I would assume the XDF100100 is just the lense and unit without the bulb holder. Quote Link to comment Share on other sites More sharing options...
western Posted June 20, 2010 Share Posted June 20, 2010 do you know any websites i can look at the parts and order from? I usually link to http://www.lrseries.com Quote Link to comment Share on other sites More sharing options...
TheTruckMan Posted June 21, 2010 Author Share Posted June 21, 2010 I usually link to http://www.lrseries.com thanks mate Quote Link to comment Share on other sites More sharing options...
western Posted June 21, 2010 Share Posted June 21, 2010 vehicle wiring products can supply too, Connectors, mounting base, trim & bulbs for lamp units. Ref-----Description-----------------------£(each) 01252----2 way connector-------------------£2.33 01253----3 way connector(use with 76718)----£2.12 on this page http://www.vehicle-wiring-products.eu/VWP-onlinestore/lighting/round.php below the Lamps with plug connection and mounting base Quote Link to comment Share on other sites More sharing options...
