classic range rover lpg
klaatu
just baught a 1992 3.9 efi on gas its the underslung tanks i tried filling her up but the gas wouldnt go in just like when there full befor i find a gas man to look at it just wondered if anyone had had the same trouble thanks steve
Are you sure they aren't full?
The inlet valve can stick, so can the non-return valve on the filler, but as it's involving LPG, if you aren't sure what you are doing, get an LPG specialist to look at it, a fix like this shouldn't be expensive.
