mudmagnet Posted June 26, 2010 Share Posted June 26, 2010 is it poss to wire up the rear windows to work without using the landrover wiring loom i have tried taking out the ecu and changed the relays but they still wont work so i just want to wire them direct from the battery i just need to know how if poss i have also changed all the window switches in case they were faulty help please Quote Link to comment Share on other sites More sharing options...
gripper Posted June 27, 2010 Share Posted June 27, 2010 yes you can, you need a live to the switch and an earth to the switch, 2 wires from the switch to the motor in the door, you'd need to look up the wiring diagram from an early discovery but it's easy enough, i did it on my last 200 no problem at all. Quote Link to comment Share on other sites More sharing options...
Tim Turner Posted June 27, 2010 Share Posted June 27, 2010 Have you tried soldering the loose joint in the ECU. Did this to mine and they now work perfectly and my kids love me. Got the instructions from this forum quite a few months ago but can't remember link. Tim Quote Link to comment Share on other sites More sharing options...
